Forgive me. I'm too noob to even know what words I should be googling.
So, I'm trying to rig a bunch of high amp (2.1A) usb chargers in my jeep. I've come across spec sheets (I think thats what they're called) on how to build one. But, most of them use the LM317 or something that doesn't have sufficient amperage to charge a single 2.1A outlet. I've also come across a few buck converters. Which also seem to lack ideal amperage and are much larger than I'd like.
The closest thing I can find is step down buck converter transformer; or so it is called. However, I'm not entirely sure how to use it without frying stuff.
So the question realistically is if anybody knows or has a spec sheet to make a somewhat small 12 volt to 5 volt usb charger handling up to 4 2.1A charging outlets at the same time safely in my jeep.
The mentioned step down buck converter transformer....
https://www.amazon.com/DROK-Converter-Step-down-Transformer-Waterproof/dp/B00CEP3A0Q?th=1
