multiple bjt switch circuit interpretation
yef smith
Joined Aug 2, 2020
1,459
Hello,there is an intresting structure shown bellow, i can that there is a form of switch being used.
from mosfet i know that Vgate above Vt opens the transistor.
But here the bjt's are in weird forms .
how can i interpret the logic of this circuit?
Thanks.
yef smith
Joined Aug 2, 2020
1,459
Hello AnalogKid,for a switch we need to use saturation region as shown bellow.
How to simulate this phenomena of floating point input BJT in ltspice?
Audioguru again
Joined Oct 21, 2019
6,826
"The bjt's are in weird forms"?
I looked in Google for Transistor Symbols and most transistors had a circle around them but a few did not.
A copy of a simulation was the only symbol with the arrow without being completely filled in:
yef smith
Joined Aug 2, 2020
1,459
Hello,first I have picked an PNP transistor as shown bellow,It has the following caracteristics of Vbe sweeps.
then i tried to simulate the first part of the circuit shown bellow.
I know that this is a floating point protection connection but what to connect to the collector in order to simulate the floating input?
I also dont know what what is a floating point voltage.
Thanks.
Audioguru again
Joined Oct 21, 2019
6,826
Your PNP transistor is in a circuit with positive voltages but a PNP uses only negative voltages, or a positive emitter.
Your base will burn out with it grounded and a positive voltage on the collector because nothing limits the current.
The collector will burn out with 360mA in it.
A simulation usually wrongly allows severe overloading.
yef smith
Joined Aug 2, 2020
1,459
Hello ,i am used to work with mosfets.
in mosfet we have Vgs>Vt to open or close and Vdg>Vt to see the formula of the biased current going threw the transistor.
I tried to read the following tutorial but i dont have this innecquality conditions in PNP .
What the the voltage innequality conditions so i could see exactly if its open or closed and what current goes threw the PNP ?
Thanks.
https://www.electronics-tutorials.ws/transistor/tran_4.html
yef smith
Joined Aug 2, 2020
1,459
Hello Audio guru, i am looking for explanation that shows PNP as if its a mosfet.
I want to know what voltage /current innequality should i use so i will know that PNP is OPEN.
and in what state ,(in mosfet its linear or saturation) so i know the exact formula of the current that goes threw.
