Multichannel analog board with saturating opamps
sim10
Joined Oct 6, 2022
24
Hi everyone, i have an analogic board of about 20 channels each of which is made by a circuit with an opamp. Each circuit is positioned in the PCB board forming a matrix, imagine that each circuit represents a node of the matrix, I have observed that, given the same Vin to all channels, the gain of the opamps more distant from the input connector gets higher hence the output saturates earlier than the ones nearer the connector. Does someone have a general idea? Can it be caused by some common-mode tension?
ericgibbs
Joined Jan 29, 2010
21,637
hi sim,
Welcome to AAC.
Do you have a photo of the layout you post, it sounds like the ground lines are the problem.
E
Ian0
Joined Aug 7, 2020
13,311
1. The circuit appears to be a transimpedance amplifier, with a current input from the socket being turned into a voltage. What controls the inout current?
2. What is your supply voltage, and what voltage is on the non-inverting inputs of the op-amps?
sim10
Joined Oct 6, 2022
24
the supply voltage is +- 15V. the signal is given with an external signal generator.
Ian0
Joined Aug 7, 2020
13,311
What Voltage is on the non-inverting inputs of the op-amps?
Does your signal generator have a current output or a voltage output?
If you drive a transimpedance amplifier with a voltage, then the output WILL be saturated.
sim10
Joined Oct 6, 2022
24
to the non inverting input I give a sinusoidal signal of amplitude 1v and frequency 30kHz. This input is given to all the channels but the ones further saturate before, this implies that I have to reduce the amplitude of the signal in order to have all the channels not saturating. However, I don't use some of them at the best
Ian0
Joined Aug 7, 2020
13,311
Whatever is happening on the inverting inputs is causing the problem.
sim10
Joined Oct 6, 2022
24
on the inverting input I have a capacitance that's what I want to measure with each channel. i don't get why more distant channel behave differently with respect to others, is there some way to avoid this?
Ian0
Joined Aug 7, 2020
13,311
How big is the capacitance you wish to measure? And how much capacitance is there between the pcb tracks and ground?
sim10
Joined Oct 6, 2022
24
the capacitance I wish to measure is 10 nF, for what regards the capacitance between the pcb's tracks and ground I cannot tell because my measurement instrument doesn't measure anything. The minimum value that the instrument can measure is 1nF
sim10
Joined Oct 6, 2022
24
Could it be that something affects the impedance of the circuit? Like parasitics capacitances?
Ian0
Joined Aug 7, 2020
13,311
What value of resistance and capacitance do you have between outputs and inverting inputs of the op-amps?
[edit] and what is part number of the op-amp. Have you checked what its open loop gain and phase shift is at 30kHz.
ericgibbs
Joined Jan 29, 2010
21,637
hi,
Perhaps a circuit diagram, with component values, for just one element of the matrix would help us to see the problem.
E
sim10
Joined Oct 6, 2022
24
the gain allows me to go from 650mVpeak-peak to 26 V, so it's about 40
