Hello!
I am trying to develop a small heating project where I will create 5 different temperature zones across an area that is about 5 inches long and 1 inch wide, with a temperature zone every inch (temperatures ranging from about 35C - 75C). Each zone will have a dedicated thermocouple and PID loop to control heat in that zone. The heating elements I'm using are custom made and as such have slightly different resistances. In the past I've used kapton thin-film heaters from Omega which had matched properties so wiring them in parallel was no problem. Here though Im finding that the differences in resistance in my custom elements are causing some elements to heat much more than others, which would, of course, lead to even worse variability as each zone switches on and off in an attempt to regulate to the setpoint. I'm wondering what approaches I might use to overcome this issue -- it seems like it should be an easy problem and I'm missing something obvious, but short of having a dedicated supply for each zone (which wouldn't be the end of the world given the scale and current requirements [ ~ 800 mA per element ]), I'm at a loss. I assume there's some kind of scheme for delivering constant current for each heater individually but I'm still pretty new to this stuff and most of my experience is with embedded circuits.
Thanks in advance for any input!
