multi-master with CAN transceiver and UART
bobfrit
Joined Jan 9, 2021
1
In the fragmentation protocol we used there was one overhead byte for 7 data bytes. So 256 bytes in a fragmented frame would be 36 frames of 7 data plus one overhead byte, plus one frame of 4 data bytes and one overhead byte. With today's multi object CAN controllers you can automate this process easily.
http://kom.aau.dk/~jdn/edu/doc/fieldbus/devicenet/v1Ch4.PDF
Read the section on the fragmentation of I/O messages.
hi im trying to acces the url that you have posted but it is not working. any chance you still have the docs?
22,084
I don't have access to the original documents, but you can:
  1. Acquire your own copy of the DeviceNet Specification
  2. Keep searching for DeviceNet Fragmentation Protocol
I may be able to answer a specific question if you have one.
