MPLAB Assembly error
30,661
Anyone have an idea on trouble shooting this error after single stepping through routine?
Pic18f23k22
Or any usual cause?
CORE-E0002: Stack under flow error occurred from instruction at 0x0000be
30,661
Is there any way in MPLAB to record or indicate the amount of cycles for a particular piece of code, without stepping through and counting?.
If it is there, I don't seem to find it.
joeyd999
Joined Jun 6, 2011
6,281
Is there any way in MPLAB to record or indicate the amount of cycles for a particular piece of code, without stepping through and counting?...
What jpanhalt said.
I have found that good code rarely requires counting clock cycles except in cases where timing is of critical importance, and then I usually let the peripheral hardware take care of the timing for me.
If you find yourself counting cycles often, you may be doing something wrong.
OTOH, I often use the stopwatch to verify proper settings for timers and other hardware.
jpanhalt
Joined Jan 18, 2008
11,087
Three places I found it helped were:
1) Working on some issue with software UART;
2) Figuring out how much data I could send between interrupts (kind of a redundant calculation); and
3) Comparing various versions of code for the same function.
I got in the habit of checking cycles, because I noticed so may posts on PicList show that metric, and it is incredibly easy to do when debugging. It takes no more time.
John
