Project MPLAB IDE using Assembly language
anukalp
Joined Jul 28, 2018
158
Hi
I want to create assembly project tp program PIC using MPLAB V 8.92
Project-> Project Wizard -> Next
Step 1 Device : PIC18F4550 -> Next
Step 2 select tool suite
Step 3 Create New project file : C:\Users\System\Desktop\Assembly Project\Test.mcp -> Next
Step Four -> Next
File -> new
save as : Test
Project -> add files to project
trebla
Joined Jun 29, 2019
599
File > New. Then type some code in the editor window and then File > Save As in your project folder. Then in the project explorer window make right click on Source Files folder and then you can add recently saved file to your project. EDIT: make sure the file extension match the language type (.asm for assembler).;)
anukalp
Joined Jul 28, 2018
158
I think I've done it.
I'm trying to understand assembly code given in here http://www.fypsolutions.com/assembl...-led-blink-code-example-in-assembly-language/
I am having trouble understanding code it's written without comments
Code:
LIST p=16F887             ;tell assembler what chip we are using
#include
<P16F887.INC>
__CONFIG  _CONFIG1, _INTOSCIO & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF & _LVP_OFF & _DEBUG_ON
CBLOCK h'20'
    COUNT1
    COUNT2
ENDC
    ORG        0x00
MAIN:
    BANKSEL        TRISB
    BCF         TRISB,0
    BANKSEL        PORTB
MainLoop:
    BCF            PORTB,0
    CALL        DELAY3
    BSF            PORTB,0
    CALL        DELAY3
    GOTO        MainLoop            ; Do it again...
DELAY3:
    DECFSZ        COUNT1,1
    GOTO        DELAY3
    DECFSZ        COUNT2,1
    GOTO        DELAY3
    RETURN
END
Please help me to understand code
ericgibbs
Joined Jan 29, 2010
21,546
hi anukalp.
Do you have the datasheet for the 16F887 PIC.??
Which parts of the Code listing do you understand and not understand.?
E
trebla
Joined Jun 29, 2019
599
To make a port pin to output, write to TRIS register corresponding bit '0', for input write '1'.
For making digital inputs you must set ADCON0 register accordingly, see section "ANALOG-TO-DIGITAL CONVERTER (ADC) MODULE" in datasheet.
trebla
Joined Jun 29, 2019
599
Information about what PIN can be set to analog is in section "Pin Diagrams – PIC16F884/887" in the drawing but better seen in the table after drawing
MaxHeadRoom
Joined Jul 18, 2013
30,776
if you need further info, look up the free tutorials by Nigel Goodwin and some really good ones by Gooligum.
Both step you through all the commands in Assembly.
anukalp
Joined Jul 28, 2018
158
Can you provide link for Gooligum tutorial which is free. I've searched but can't find
