mounting speaker and mic
bug13
Joined Feb 13, 2012
2,002
Hi guys
How can I mount a speaker and mic on a plane without getting feedback? The plane(speaker and mic) needs to be mounted on the ceiling.
The speaker need to be heard reasonably well, and the mic needs to be able to pick up voice.
bug13
Joined Feb 13, 2012
2,002
Is the speaker re-broadcasting what the microphone is picking up?
It's going to be a two way communication. The speaker is connected to the the mic on the other end with similar configuration. The speaker is suppose to broadcast whatever from the other end.
The goal is enable people in different room can speak to each other. But I believe I am having feedback problem.
Lestraveled
Joined May 19, 2014
1,946
Try changing the phase of the speaker. If this does not work then the fixes get more expensive.
Graphic equalizer - Notch out the frequency of the predominant feedback frequency.
Feedback killer - A delay generator for audio use. This device inserts very small amounts of delay to change the phase of the feedback.
Check music stores for both of these devices.
34,826
You can also use an echo cancellation mic. A signal from the speaker is fed back out of phase into the microphone preamp circuit thereby cancelling the sound picked up from the speaker.
bug13
Joined Feb 13, 2012
2,002
What do you mean by changing the phase of the speaker? Like switching the connection of the two wires to the speaker?
bug13
Joined Feb 13, 2012
2,002
Never know this, I think I need to google this, thanks!
to3metalcan
Joined Jul 20, 2014
263
The pickup pattern of the mic makes a difference, too...an omnidirectional capsule is going to "hear" the speaker lot more than one with a more unidirectional pickup pattern.
Alec_t
Joined Sep 17, 2013
15,121
Because of sound reflections in each room that will inevitably lead to feedback unless a) each room is made anechoic or b) both mics are muted, made highly directional or screened, to prevent pickup from general room noise. A signal feeding the speaker in a given room could perhaps be used to mute the mic in that room?
bug13
Joined Feb 13, 2012
2,002
That might be a good solution for my application, I will talk to other people and see what they think.
