Motorcycle Voltage Regulator ---- AC regulation
abuhafss
Joined Aug 17, 2010
307
Hi
I have been working on 4-pin Voltage Regulator (Single Phase) for Honda CG125. After trial & errors I learnt that, that model has dual coils in the stator, both having one end grounded to the chassis. 12-50VAC (depending upon the RPM) from one coil is fed into the Regulator Unit which converts it into 14.4V DC for charging the battery. Similary 12-50VAC from the other coil is also fed into the Regulator Unit but, it is also connected to Head Lamp & Tail Lamp via switch. The Regulator Unit have 2 circuits, one converts to 14.4VDC and the other regulates to 12-14VAC for the Lamps.
I ripped a Chinese Regulator unit and found circuit as below:
This design does not provides regulated charging voltage to the battery.
I also found a similar circuit on the net as below:
I am unable to simulate either of these circuits.
However, I came across an old Thread on AAC, http://forum.allaboutcircuits.com/threads/12v-ac-motorcycle-regulator.39419/page-8
The circuit posted by Sgt.Wookie at #153 perfectly regulates 12-50VAC to 12-14VAC, but it requires a huge 25A bridge. I also attach the spice file for this circuit.
MY CONCERNS:
1) Why the other two circuits do not simulate? I have used LT Spice and Falstad.
2) Alternatively, I would like some other circuit with minimum number of components.
Thanks in advance.
AlbertHall
Joined Jun 4, 2014
12,347
It only needs a 25A bridge if your alternator is capable of producing 25A which I seriously doubt. That circuit also dissipates lots of power in the transistor while the thyristor versions keep heat to a minimum.
Alec_t
Joined Sep 17, 2013
14,330
For LTspice try
1) modelling the generator as an AC voltage source with a finite series resistance (say 2 Ω),
2) adding a load across the SCR (say 6Ω).
3) adding the directive ".options gmin=1e-7".
abuhafss
Joined Aug 17, 2010
307
I had tried physically with 4 x 1N4007 (considering that the Chinese circuit used 0.5A bridge). Two of them were blown. So I have to try 5A or 6A but again 4 x 6A diodes would occupy big space. And yes, I had already replaced the transistor with BT151.
abuhafss
Joined Aug 17, 2010
307
For LTspice try
No. 1 & 3 worked. No. 2 drops the voltage further.
But the output remains constant, altering the zener value has no effect.
Dodgydave
Joined Jun 22, 2012
11,304
The scr with the zener sets the minimum voltage, once the thyristor has fired it will continue to conduct,, until the alternator output is zero, so the battery over-charges, your better using a mosfet and aTl431 variable zener to set the voltage.
Ideally you need to know how your alternator is wired, then you can design one.
abuhafss
Joined Aug 17, 2010
307
The Regulator Unit or the Charger Unit comprises of two parts, as I described in my first post. Please see the first diagram in that post.
The first part (the yellow box) converts the AC voltage from the generator to regulated 14.4VDC to charge the battery.
The second part (the green box) converts the AC voltage (12-50V) to regulated AC voltage (12-14V) for Lamps only.
In this thread, my focus is only on the the second part i.e. regulation of the AC voltage.
abuhafss
Joined Aug 17, 2010
307
Here is the snapshot of the simulation. The maximum regulated voltage for the LAMP OUTPUT should be 14V.
Alec_t
Joined Sep 17, 2013
14,330
Not so when I tried a sim of the circuit. Part of the negative half-cycle gets shunted to ground. The timing/size of that part depends on the zener voltage.
The maximum voltage for the LAMP OUTPUT should be 14V.
I think the RMS voltage is more important at the sort of rpm which will give a generator output greater than 12V.
Use of a constant current load (I2) is unrealistic and can give strange sim effects.
abuhafss
Joined Aug 17, 2010
307
Would you please share the schematic of your sim?
Even if I replace I2 with a load resistor, same results :confused:
abuhafss
Joined Aug 17, 2010
307
Here you go
Hmm, now I got it. But I don't think this regulation is giving any sort of protection to the Lamps; correct me if I am wrong.
Frankly, I was expecting the complete cycle to be regulated as sim by Sgt.Wookie's design which is supplying constant regulated AC voltage.
abuhafss
Joined Aug 17, 2010
307
Modifying the Sgt.Wookie's design, I could get following results:
But I could not get why the power dissipation is increasing after 8sec.
Shall appreciate valued comments for optimizing this design. And suggest me suitable triac in TO-220 package.
abuhafss
Joined Aug 17, 2010
307
I assembled the above circuit using BTA16, 0.5W zener and 120Ω resistor. The triac became hot and the zener became warm in 30 sec. To avoid any damage I power off the bike. Then, using the OEM regulator, I took measurements at point indicated by blue arrow:
Idle = 8VAC, 0.5A
6000 RPM = 12VAC, 2.45A
Idle+Lamp ON = 6.5VAC, 0.5A
6000 RPM + Lamp ON = 12.3VAC, 1.70A
Observing the measurements, any ideas why the BTA16 is getting hot?
Dodgydave
Joined Jun 22, 2012
11,304
The Triac is shorting out the AC supply for regulation, so it will get hot, looks to me like a stupid design.
Alec_t
Joined Sep 17, 2013
14,330
Any shunt regulator will involve components getting hot, since the shunt action has to dump excess generated power somewhere. You could include a power resistor in series with the triac in your design, so that the dumped power is shared between the resistor and the triac.
