hi everyone
I bought one of those all-in-one LED strip with running, brake and turn signals
There are 5 wires:
1) ground
2) running light
3) brake light
4) left signal
5) right signal
they all share the same ground wire (1)
BUT, my bike's stock wiring has separate ground wires, 1 for running/brake, 1 for left signal and 1 for right signal respectively
if I connect the LED strip's ground to the running/brake's ground, the turn signals will always be blinking as if its circuit is always closed
how should I wire to make the LED strip's turn signal function normally?... thank you......
There are 5 wires:
1) ground
2) running light
3) brake light
4) left signal
5) right signal
