Hello everyone,
I got an old motorcycle (Sachs 125cc) and I need to fix my front headlights, because their lighting isn't powerful enough. I am not using a battery for them and they only work with the dynamo. As a result when I hit the gas the headlights shine enough and I want to keep that light consistently. The problem is that I can' keep that light steady because, I don't hit the gas for ever, as a result the light's level is going down. I have attached a photo with the dynamo and the yellow cable is the one that goes to a switch and from the switch to the front headlights. Is there any module that I can attach in series to that yellow cable in order to keep the voltage constant at 6 volts ? (I am not using a battery for the front lights)
Thank you so much for your time, appreciate your help.
![Test.png Test.png](https://forum.allaboutcircuits.com/data/attachments/243/243154-150d7350542aa62aaddce0e57e7b06bb.jpg)
