Motor running capacitor...
Externet
Joined Nov 29, 2005
2,681
Hi.
I have two equal 230VAC squirrel cage fan airhandlers for dwellings central airconditioning and heating. One has a motor with a 3μF run capacitor; the other uses a 7.5μF run capacitor. Both units have 3 speed selection, both are preset for 'high'
What in the motor characteristics/specifications determine the capacitor value fitted ?
28,578
Usually the capacitor value is determined by the motor power rating. That includes both the running torque and the starting torque, and the running speed. A motor with a lower starting torque will usually take longer to reach the rated speed, which mightbe desired in some air handling applications.
MaxHeadRoom
Joined Jul 18, 2013
30,881
Hi.
As a general rule the 1ph capacitors are aimed at achieving a 90° phase shift of the start winding, WRT the run winding. if this is a multi speed version the centre is aimed at 90° and the other windings either side of it.
