motor over current sensing circuit
hp1729
Joined Nov 23, 2015
2,304
Hi, i need to build a circuit with the following spec:
using a 12v supply I need to run a 6v servo motor (with internal resistance of 10ohms)
-when the current on the motor will be more than 1A, i need to cutoff the power to it, and light a red led light.
-when the current goes down 1A, the power can only be restored by pressing a reset switch (which will also will turn the led light off).
the thing is i can only use simple components (diodes, transistors, resistors, op amps etc, NO IC, relays, software...)
Moderator's Note.
Please don't do double post, one thread is enough.
No programmed chips? Okay what is allowed? Op amps, voltage comparators and logic?
Attached is a consideration for a design, not exactly to fit your needs, but would this design be okay?
hp1729
Joined Nov 23, 2015
2,304
Moderator's Note.
Okay, only an op amp and parts. Not a complete design yet. It is a 6 V regulator, current limiting set to 1 A. Reset button. LED on over current. Allowing for over current on power on to the motor. Another starting point.
Still some designing required.
segalamit
Joined Feb 18, 2017
15
the circuit looks good, and thank you for the extra information.
i really liked the voltage divider you added (exactly what i needed)
but the thing is on the simulation - when i get more current on the motor - there a big voltage drop.
I'm using multisim, i couldnt find LM334 - so i used LM333K instead - is that okay?
