Hi, i need to build a circuit with the following spec:
using a 12v supply I need to run a 6v servo motor (with internal resistance of 10ohms)
-when the current on the motor will be more than 1A, i need to cutoff the power to it, and light a red led light.
-when the current goes down 1A, the power can only be restored by pressing a reset switch (which will also will turn the led light off).
the thing is i can only use simple components (diodes, transistors, resistors, op amps etc, NO IC, relays, software...)
Moderator's Note.
Please don't do double post, one thread is enough.
Moderator's Note.
