But what i main encountered is the when the ir beam faced toward the base of phototransistor. The phototransistor's emiiter doesnt have enough power to operate the npn transistor (base of npn). So i guess this why the trigger is "high".
Wont light up too. I guess the ic is burned . But by theory this circuit should work like a charm right?hi T,
OK.
Keep the resistor and LED connected to pin #3.
With a short piece of wire touch across pin #2 [ trig] to 0v, this will simulate the the action of the photo-transistor and the 555 should switch the LED.
Lets know.
E
Dont disconnect the photo transistor parts
I placed it very near. So maybe external light is not a big deal i dont know. But the problem is i afraid the phototransistor's emitter will release over-voltage to the base of the npn transistor. Or too less voltage to the base of npn.Hello,
I see that the phototransistor is in the open.
External light might already have such an influence that the circuit does not react.
Please place the phototransistor is a piece of tubing, so that external light is shielded.
Bertus
They worked very well.hi,
The circuit will work OK.
Have you checked that your 470R and LED test circuit is OK.?
To check it, connect the 470R to the +9v and the free end of the LED to 0v, it should light.
E
Do you have a test voltmeter.?
YesDo you have a test voltmeter.?
U means pin 2 to gnd?OK,
Measure between pin #2 and 0V, is it at 0V or +9v??
50mV something..Yes, measure pin 2 to 0V voltage
YesOK,
Connect your test resistor and LED to pin #3
Unplug the photo transistor, pin 2 should then go to ~9v, remeasure pin#2 to 0v
Even i switched the pin 2 wire to gnd led still no light up.Good, keep the phototransistor unplugged, repeat this test.
Nope.ok,
That suggests that the 555 is faulty, do you have another one handy.??
