If It is physical damage like a scrape (not electrical short/spark), you can gently pull them apart to make sure they are not overlapping or physically connected and then coat the damage with epoxy or other good insulator.I damaged my MOTs primary and i wpuld like too know if the primary can still be usedView attachment 144127
Ok thank you very muchIf It is physical damage like a scrape (not electrical short/spark), you can gently pull them apart to make sure they are not overlapping or physically connected and then coat the damage with epoxy or other good insulator.
