Most efficient/simple voltage reduction
Col
Joined Apr 19, 2012
44
I want to generate 1.8V (1.6-2.2 is ok) for a very low power application (active RFID, needs about 150uA). Batteries are unfortunately not available in this range (correct me if I am wrong). I want to getenrate a voltage suitable for my RFID, and it does not need to be well regualted. An LDO is out as it will just burn power, similar for a simple R divider. I'd rather not go down the roade of switching regulators if I can avoid it.
So im thinking along the lines of diode. Could I just put a 1.2V Vf diode between the battery and load? I thought about a zener with breakdown of 1.8V but wont this just short out higher voltages and quickly drain the battery
Tnx
kubeek
Joined Sep 20, 2005
5,796
What kind of RFID? Right now I am playing with 14443 at 13.56Mhz, and I am using LTC1771 step down converter.
I am still trying to finish the data transmission, and after that I will again try to get it to work from just the RF field energy.
12,268
If you rule out linear regulators, switching regulators, and voltage dividers, I'm not sure what's left. Unless you are dealing with a relatively high voltage source, like 6 volts, a switcher is way too complex for the job. A series regulator will be more efficient than a shunt regulator like a zener diode or LED. But no matter how you do it or how small the load is, regulation requires headroom, and headroom costs watts. Without some operational parameters, there can be no "best" answer.
What is the battery voltage and capacity?
What is the expected battery lifetime?
kubeek
Joined Sep 20, 2005
5,796
On the other hand, a shunt regulator used on the primary side of a step down converter might have some benefits for this particular purpose, as it will keep the load on the LC tank fairly constant.
This will keep your tuning frequency and bandwidth constant as well, which should help with reliable data transmission.
ronv
Joined Nov 12, 2008
3,770
Sounds like you are using a 3 volt cell. So my thinking is just a couple of silicon diodes (1N914) in series with the 3 volts. Follow this with a 10 Meg resistor to ground and a small filter cap. Probably around 65% efficient. Not sure you are going to do much better.
18,162
I thought about a zener with breakdown of 1.8V but wont this just short out higher voltages and quickly drain the battery?
Not necessarily. You could set the zener current to, say, a max of 400µA. For instance: 3V cell + 3KΩ resistor + 1.8V zener.
When the load comes on line, it will take 150µA and the zener will take 250µA. I believe a zener would have no trouble holding the voltage within the range you gave while passing these low currents.
Tnx
What ever you use to drop volts will use power.
The only way around that is a DC-DC converter.
Col
Joined Apr 19, 2012
44
Thanks all for the comments.
Its UHF RFID, 868MHz, aiming for 6-8m distance, NFC band could more easily take power from the reader
Won't the LDO be much less than 50% efficient factoring both the voltage 'burn off' and quiescent current. I don't have a way to shut it off
wirelessly (infact the reason i need to add power is to drive an RFID digital output wirelessly) but its for a demo so the enable of the LDO is handy, but equally could just break to circuit at the diode
Rony: series diodes sounds the simplest and 65% efficiency I can handle, probably I'll go with this solution
Analog Kid: Thats just what I was thinking too, Battery will be a 3V button cell like CR1220 (40mAhr), Battery life should be as long a possible.
Lead acid battery it is then, I guess they can integrate them on silicon now. :)
Thanks for the reference Mike, but am i missing something here? 1.55V is too low, I need 1.8V (or an absolute min of 1.65V, not recommended)
