Most efficient power management when splitting battery voltage
Binary Buddha
Joined Sep 24, 2016
40
So if I wanted to reduce the voltage of a 9V battery down to 3.7ish voltage... what would be the best way? Using resisters to split the voltage or doing the voltage regulator dance? Is there any other method to step down voltage?
Obviously, I'm trying to keep the result circuit size to a minimum whilst trying to maintain optimal power efficiency.
Binary Buddha
Joined Sep 24, 2016
40
How much current do you want to draw from the 3.7V?
Various... Where would you draw the line? Let's say 3000mA (10W) for one thing at the moment.
There's also the idea of making a 9V battery supply 5V 2.1A and what not.
In short, I've heard that a voltage regulator is the best solution for low-steping voltage if the power supply in continuous and consistent. But, I have heard anything about if you use a battery. And I know know battery power is quite the opposite. The battery voltage continuously drops when it's being used. Which would throw off the design specs of any circuit.
38,946
A standard 9V "transistor" battery will never deliver 10W for any significant length of time (beyond a few seconds).
You will need a much larger battery for that.
How long do you want the battery to last at that load?
Binary Buddha
Joined Sep 24, 2016
40
Okay... Then let's say we chained a bunch or C or D batteries then.
38,946
Alkalines will give you 1.5V per cell.
So what exact voltage and current do you need, and for how low before the battery is dead?
Binary Buddha
Joined Sep 24, 2016
40
I'm actually looking for the theory of what would be the best to do. Not to be spoon fed a solution.
Would you be able to explain to me what would be best under certain circumstances? I know it's not "simple". Hence why I'm asking for guidance.
From your responses, (thank you btw) I'm assuming that if I need high current it's best to use resistors to split the voltage. Which would lead to the question of what should I do with with the second Vout from the split? Can or should or just ignore it? I know that most of the voltage regulators can go up to 5 amps out max. So, question would lead to if I need less than 5 amps would it be better to use a voltage regulator over resistor voltage splitting?
AlbertHall
Joined Jun 4, 2014
12,663
You would use regulators for high current.
For very low output currents you can use resistors and the current through the divider can be much greater than the output current and thus keep the voltage reasonably constant.
38,946
Just the opposite.
Resistors are only good for very low current.
So you need a regulator as AH stated.
A linear regulator is simple but is not efficient as it wastes energy (Vin-Vout) * Iout as heat.
So if you need higher efficiency you would use a more complex switching regulator, which generally has efficiencies in the 85-90% range.
Binary Buddha
Joined Sep 24, 2016
40
So, if I were to use something like an LM317 to drop 12V to 5V USB would I be able to hit 4+ amps? What would the max amps be on a LM317? Trying to build a usb fast charger into a dashboard thing I'm making.
Large voltage ratio...Medium to high currents...High Efficiency...This sounds like a job for a Buck Converter!
lol... I'm too noob to start playing around with buck converters yet. I'm still learning how to use my LM317s.
35,299
You need to rethink your strategy.
12V @ 4A = 48W
Your load is taking 5V @ 4A = 20W
You have to get rid of 7V @ 4A = 28W
You have to waste 28W in a resistive device such as LM317. The LM317 is going to get very hot.
A more efficient solution is a buck converter.
