most efficient heater
Reloadron
Joined Jan 15, 2015
7,922
There are dozens of types and designs for electric heating for hundreds of applications. There is no most efficient as efficiency depends on application and oter factors.
Ron
Reloadron
Joined Jan 15, 2015
7,922
OK then Electric resistance heating is 100% energy efficient in the sense that all the incoming electric energy is converted to heat. However, most electricity is produced from coal, gas, or oil generators that convert only about 30% of the fuel's energy into electricity. Since all of the electrical energy is converted into heat an electric home heater is 100% energy efficient as no energy is lost in the conversion process. Now the cost of making the electricity is another story.
Electric Resistance Heating
Ron
AlbertHall
Joined Jun 4, 2014
12,651
Yes, even if it is a fan heater, and some of the electrical energy is used to drive the fan, but all that 'lost' energy will also end up as heat in the room.
It matters not whether the element is the 'latest high efficiency quartz' or a very old bare resistance wire, the efficiency is still 100%.
AlbertHall
Joined Jun 4, 2014
12,651
What about light?
If the heater produces light then that will also end up as heat in the room as long as you keep the curtains closed ;)
DickCappels
Joined Aug 21, 2008
10,662
Watts is watts no matter how you dissipate them.
I have two 1 kW electric clothes irons and a small muffin fan to keep my office warm the two or three weeks a year that it is needed. A lot easier to store than a regular space heater.
ElectricSpidey
Joined Dec 2, 2017
3,357
While all electric heaters are 100% “electrically” efficient, even what is wasted in the power cord is converted to heat, a few things should be considered.
  1. Convection heat (forced air) is best at quickly heating air.
  2. Radiant/ reservoir (oil filled) is best at heating air and objects over longer periods.
  3. Pure radiant (quartz and such) is best at heating objects.
Externet
Joined Nov 29, 2005
2,667
The newest super-high technology fancy and expensive electric heaters in the market produce exactly the same heat as a falling apart rusty heater from the 1920's per Watt inputted.
The difference is only the lifetime duration of the newest, which cannot compete.
tcmtech
Joined Nov 4, 2013
2,867
Yep. I've made it a minor mission to rescue old heaters from scrap yards and auctions then rebuild them and give them to people who need decent long lasting heaters that will stand the test of time.
Personally I like the old all metal 'Milkhouse' heaters from before the 1970's being most of them went up to 1800 - 2000 watts on high rather than the now 1500 watt limit.
Typically I rebuild them with updated 4.5" box fans I get out of salvaged industrial stuff that don't rattle an they move more air too. The rest is basic high temp paint jobs, fixed thermostats and better and longer 14 ga power cords over the all to common stock 16 ga (yea, 16 ga for 1500 - 2000 watts. :eek:) types they came with. :cool:
After that, I like the old quartz element radiant heat units. Just as simple rugged and reliable. ;)
