MOSFET's - Just curious
Ford Prefect
Joined Jun 14, 2010
245
Hi guys,
I have been using MOSFET's for years and all the schematics that I see have the MOSFET's connected as shown in schematic 1 below and I have followed this method/rule/convention of connecting the MOSFET with the load between the Vcc and the MOSFET Drain.
But I am just curious and have not tried it, but can a circuit be connected as in schematic 2 with the load between the GND and the MOSFET source?
If it is possible to connect it as in schematic 2, why is it that all schematics are shown as in schematic 1 - or is it just a convention that people use?
bertus
Joined Apr 5, 2008
22,923
For using a N-fet as a high side switch, you will need a high side driver.
The N-fet will only work when the gate voltage is higher than the source.
Bertus
Ford Prefect
Joined Jun 14, 2010
245
Bertus
Hello Bertus, thanks for your answer. But a MOSFET is just and acts like a toggle switch, if used as in schematic 2 it is just providing the Vcc to the other side of the load which is connected to GND. - Or am I missing the point?
GopherT
Joined Nov 23, 2012
8,009
Hi guys,
If it is possible to connect it as in schematic 2, why is it that all schematics are shown was in schematic 1 - or is it just a convention that people use?
It will work but, BUT,
If you have a standard MOSFET that needs the gate to be 10v above the source, the gate, in drawing #2 will need 22v if V+ for the relay is 12V
joewales44
Joined Oct 8, 2017
218
finally someone with the same question i had.
i had a hard time grasping this too.
just remember the gate must see a 'difference' in voltage from the source/drain, not just any signal.
most need 10 volt difference to fully turn on.
dl324
Joined Mar 30, 2015
18,326
You should just try it. When you do, you'll find out why it has issues and a P MOSFET would normally be used to drive a relay high side.
