MOSFETs and current output
Schidtztorm
Joined Oct 1, 2019
77
I have a dilemma! I'm building a phone charger. I'm using two small npn for a differential type regulator that is controlling a mosfet for current. I'm trying to get this thing to put out 1 amp, or at least 700 mA. It's only putting out around 200mA.
I'm currently using a 2sk3568. I posted schematic below.
What am I doing wrong?LG
ronsimpson
Joined Oct 7, 2019
4,763
Vin (input voltage) needs to be 5 volts or more above Vout, which is +5V.
What is the input voltage?
Think: What is the G-S turn on voltage for the MOSFET at 1A?
Schidtztorm
Joined Oct 1, 2019
77
Try reducing the emitter resistor from 25k to 10k.
Will do! Thank you.
I had a question for you as well. They've been upgrading AAC so you probably didn't see it.
if I have an identical FET, could I run them parallel on the same circuit? And would it double the current? Or would it stay the same? I never tried such a thing.
Dodgydave
Joined Jun 22, 2012
11,395
Your circuit is useless, just use a simple Emitter follower transistor TIP41 with 6V zener on the Base , this will give you 5.3V on the battery and as much current as the supply and transistor will give...
DickCappels
Joined Aug 21, 2008
10,662
You really should consider some current limiting for your circuit -there is no "intentional" current limiting in the circuit, so you have no control of how much current this circuit will try to shove into a battery if you connect a dead battery to it.
This circuit may look familiar. When the current through R2 develops enough voltage across the base-emitter of Q2 to make it draw current, the transistor will begin conducting, starving the base drive of pass transistor Q1 thus limiting the current to the load. This works with MOSFETs too.
Schidtztorm
Joined Oct 1, 2019
77
The phone, as well as the lithium ion battery both have current limiting of 500mA. I want more because I want to use it while charging at the same speed. Fast chargers from the manufactures are 1000mA. I'm just trying to get close to that with what I have. Which are small L6 npn's and assorted N channel mosfets.
Schidtztorm
Joined Oct 1, 2019
77
I do like this circuit. It would stay the same for fets? Could I get an amp out of this using what I have? You don't think what I'm using will work?
Schidtztorm
Joined Oct 1, 2019
77
In place of the 50k and 25k. Either way it should work. But I can't trouble shoot with out knowing the voltages.
I just built it in SPICE using your values and it works for me.
I'm going to rebuild this thing with some variations. First I'm going to eliminate the 5V zener. It's not 5.1.
I'm going to put 14400 ohms above 10k to make 5.12V which pushes the max base V over by 120mV. I'm hoping the little L6's have at least that much tolerance. Then swap out the 25k for a 10k as Crutchow recommended.
What do you think?
38,655
No, because there can be a significant difference in the gate-source threshold voltage even between two MOSFETs of the same type.
The one with the lower Vgs(ths) will hog most (or all) of the current.
Schidtztorm
Joined Oct 1, 2019
77
5.0V Zeners are not common. 3.3, 3.6, 3.9, 4.3, 4.7, 5.1, 5.6 are common 5% parts.
Yeah! I'm also aware of that, but it's 5V just the same. It's a little glass one.
I built the one I previously mentioned above, with the 5.12V voltage divider, and swapped out the 25k for the 10k. Still no change. Still at around 200mA.?
Any suggestions that will make this circuit work better? Maybe a coupling cap? My supply pulses along side of a week DC signal.
Schidtztorm
Joined Oct 1, 2019
77
OK, thank you for that. Now I know better.
I just did as you suggested and a little more. I swapped out the 25k for the 10k, and swapped the 5V zener for a voltage divider to give the L6's 5.12V. Still at around 200mA. Would it make any difference if I used a coupling cap? Even though my power supply has one out at its output? It is a pulser with a week DC along side of it as most are these days?
