MOSFET Transistors
wayneh
Joined Sep 9, 2010
18,151
You'll learn more faster by just reading, then asking here any questions you still have.
Virtually every experiment you can imagine has a predictable outcome. In fact using a circuit simulator such as LTspice is a good way to experiment without cost or risk of burning up a component.
Don't get me wrong: Playing with real components is a good way to learn and to help make the learning permanent. But it's better as the last step in the process, not the first.
srtech90
Joined Feb 28, 2025
23
Thanks Wayne!
LowQCab
Joined Nov 6, 2012
5,102
Sayal Numbers ............
Part#:IRFP250 Stock#: IRFP250-1 SKU: 186672
( Dang-it-man !!!! almost twice the cost of DigiKey in the States !!!!! )
This part-number is just a generally-tough, generic, high-Voltage, N-Channel-FET,
which should make it slightly more difficult for You to smoke when
the inevitable wiring mistakes are made..
Hopefully You will be using a Power-Supply with limited Current-capabilities.
It has a Heavy-Duty TO-247 Package which should mean that,
for most low-Power Tinkering-Circuits, it "probably" won't need a Heat-Sink.
But You should use some kind of a Heat-Sink anyway.
Just because it has stout ratings, doesn't mean You cant easily smoke it for a variety of reasons !!!!
What other questions do You have ?
Starter NFET Circuit .png.
dl324
Joined Mar 30, 2015
18,454
Could someone please
recommend which components I should purchase for this purpose.
Didn't check the link, but I'd get complementary power devices (IRF44N IRLZ44N/IRF4905) and small signal devices (A03400/A03401).
The former are in TO-220 so you can breadboard with them, but I'd twist the leads 90 degrees to be more compatible with solderless breadboards. The small signal devices are in SOT-23 and would require an adapter for through hole work.
You might find some useful information in this thread on MOSFETs.
srtech90
Joined Feb 28, 2025
23
View attachment 348043.
Thanks for the info.
I am still studying MOSFETs so I will likely have some questions down the road.
srtech90
Joined Feb 28, 2025
23
Didn't check the link, but I'd get complementary power devices (IRF44N/IRF4905) and small signal devices (A03400/A03401).
Thanks for the info! I am still studying the MOSFET so I may have some questions down the road.
sarahMCML
Joined May 11, 2019
703
If you need to drive high current MOSFET's directly from 3.3 or 5V logic, you need to choose Logic Level types, such as the IRLZ44 version of the IRFZ44, or else use a level translator or purpose designed driver chip.
dl324
Joined Mar 30, 2015
18,454
I had a typo on the part number for the N channel power MOSFET. It's IRFZ44N (dropped the L Z when I edited it from IRLZ44N).
srtech90
Joined Feb 28, 2025
23
Thanks DL324
