Mosfet gate resistor voltage drop
adam450
Joined Mar 19, 2019
34
Something I never understood ( I don't have an electrical degree). Resistors have a voltage drop. 1 resistor from 5 VCC to ground will have a 5V voltage drop because well it hits ground and has to have 5V potential on one end and 0 on the ground. 2 resistors in series will have 2 separate voltage drops.
If I have then a resistor in series with a mosfet, then why doesn't the resistor have a voltage drop? Is the gate of the mosfet such a high resistance that it doesn't matter? The resistor would obviously slow the current into the gate charge, but why isn't there a voltage drop? Or will the gate slowly get up to 5V over time once the gate capacitance is charged and fully stops electrical current, essentially becoming a very high value resistance?
Papabravo
Joined Feb 24, 2006
22,113
Because the MOSFET gate "looks like" a series RC circuit, you know from the solution to that 1st order differential equation that the current starts off at a high value and as the capacitor charges up exponentially the voltage drop declines exponentially from Vgate to zero. The thing that is hard to wrap your head around is that NOTHING is constant, unlike it is with DC circuits.
Check out this simulation: Green trace is the current in the resistor. Blue trace is the voltage drop across the resistor.
dl324
Joined Mar 30, 2015
18,474
There is a voltage drop across the resistor while the gate capacitance charges. You can't measure it unless you have an oscilloscope.
If 5 RC time constants can be considered slow.
