Hi All,
I'm hoping there's some expertise that can quantify the dimensions of my ignorance. This is a high power (2kw) offline 2-switch forward converter project. Obviously this is not the natural topology for applications at this power level but I had read this was possible though clearly not the right option commercially. The board is based on a UCC28513 combined controller with integrated gate drivers for both boost pfc stage and PWM for DC-DC converter. The board is built and seems to function correctly up to the main transformer. The pfc stage correctly regulates at 385V.
The issue is with the forward converter section. The two switches are driven using a double dual duty transformer coupled gate drive circuit. So the gate drive signal from the controller is capacitively coupled through a 1:1:1 pulse transformer which is rectified providing both power and signal to a pair of ucc27424 (4A peak gate drivers). For what it's worth, without the mosets populated the gate drive signals they generate look good on the scope.
Looking at the figures you might see the layout is, let's say, suboptimal. All, or most, of the high dissipation components where aligned to use a single large heatsink. I realise that the respective grounds of the two gate drive circuits are high current paths, with switching occurring at 100 KHz going from conduction to freewheeling. I just couldn't see a way of avoiding this.
Long story short, when turned on detonation occurs. The main victim is the PWM current sense resistor (30W, 0.068 Ohm). Seems to me that the mosfets fail short circuit, a few microseconds later the primary winding saturates, essentially shorting the 385v bus through the current sense resistor. The transformer is sound, saturating at around 16 A (500 uH primary). I don't think that's the issue (it was before, lol).
My feeling is this is a high dV/dt or dI/dt issue. The gate drive current loops are tight but the power loop is clearly quite big. This seemed unavoidable during the design. Both Mosfets and freewheel diode are good quality 600v with current rating with healthy margins. In my naïve enthusiasm and lust for efficiency, I've used 1 ohm gate drive resistors (anti-parallel diodes for turn off). I'm going to slow the turn on with higher values (got some 20 Ohm 1206s to hand). I've killed some of the finest mosfets money can buy. Its broken my heart. I'm using cheaper ones (higher Rdson) until I know what the problem is.
Obviously there's a lot of information missing that might help and can be provided, but anything that anyone could add would be helpful. Thanks in advance.
