MOSFET Drain Source resistance
Irving
Joined Jan 30, 2016
5,195
Drain-source resistance, Rds, is lowest when MOSFET fully turned on, ie gate-source voltage >> gate threshold voltage Vgs(th).
MOSFET is never a current source, but can be configured as a constant-current sink and is often used as such for active loads. A typical circuit being this one I am currently testing...
BobTPH
Joined Jun 5, 2013
11,632
A MOSFET does act somewhat like a current source when it is in saturation mode. For any given gate voltage, there is a max current after which the current increases very little with increase in Vds.
Bob
Irving
Joined Jan 30, 2016
5,195
Bob
Hmmm - when configured in a constant current configuration I suppose you could say its a current source, but that's not the MOSFET, that's the circuit configuration. It isn't a current source in the sense that a battery is a current source.
Audioguru again
Joined Oct 21, 2019
6,826
Is the load actually 0.75milli-ohms which is only 0.00075 of an ohm?
The Mosfet needs a Vgs of 10V to fully turn on and the minimum opamp output voltage will be 11.2V then the output current will be (11.2V - 10V)/0.00075= 1600A (!) and explode it and the battery if the input voltage is at the maximum input for the opamp of 12V - 1.5V= 10.5V.
If the load is actually 0.75 of an ohm then the output current will be 667mA.
38,741
Well, the added circuitry controlling the MOSFET does help in establishing and stabilizing the current-limit, but the MOSFET makes a pretty good current-source by itself if operated in the saturation region (below), as can be seen by the near constant current for a change in the drain-source voltage.
Irving
Joined Jan 30, 2016
5,195
OK, that might have been a bad choice of example, it was a WIP on another project and I picked the first diagram with a single MOSFET as an example confi. For completeness here are the LTSpice generated curves for that device for Vgs = 4.15 - 4.85V:
I don't have the actual real device curves to hand but they were remarkably similar - better than I expected.
Here is the actual circuit I'm testing, though right now the heatsink isn't big enough to go to 40A @ 28.8v design spec at 10m/s air flow. I'll probably end up using two of the heatsinks I have now and 6 MOSFETs in total (at £28 each I'd rather not fry them too often). The sense resistors are 50A/75mV ammeter shunts - a lot cheaper and easier to use than PCB mounted devices - I was originally using 100A/75mV ones as I had a couple to hand but they are a little insensitive at low currents.
This works pretty much as per the simulation though it drifts off a little as the devices heat up - only to be expected. Right now I'm playing with ideas to select 1, 2 or 4 MOSFETs and changing loop gain to make it a little more flexible at lower currents, say <20A and <10A,the approx limits for 2 and a single MOSFET.
Even so, a 16bit DAC on 3.3v full range gives a (noisy) resolution of around 20mA though realistically I'd say 200mA steps are more practical for all 4 MOSFETs which is fine for my immediate needs.
