Morse Code Audio Tape to Sounder
Status
Not open for further replies.
Sensacell
Joined Jun 19, 2012
3,789
Looks like a good circuit, it should work.
The diode D1 is in the wrong place, should be placed across the sounder, not the transistor.
Start building!
KB3TZB
Joined Feb 9, 2018
10
Start building!
I have rebuilt this circuit several times with limited success, including the modification you suggested. With a 2N2222 in place of the TIP 31 it worked at the museum for two weeks, then failed. I have a working telegraph relay that I can drive with 540 mWatts. I measure the tape output at 0.8 mWatts. I am looking for a 28 dB amplifier to power the relay. The relay works the sounder fine when the proper power is applied. A power amplifier circuit will be much appreciated. Regards, Morgan
AnalogKid
Joined Aug 1, 2013
12,283
3 V and 20 ohms works out to 150 mA. That's a bit high for a 2N2222 (2N3904, 2N4401, etc.). If it is not being driven into firm saturation, death after 2 weeks might be due to overheating. Try the same circuit with the TIP31 (note the pinout difference). No heatsink necessary, the larger package should suffice.
ak
MaxHeadRoom
Joined Jul 18, 2013
30,854
You might also get away with a modern alternative, a 2n7000 fet.
Does the Russian news agency TASS still broadcast in Morse, we used to use it for practice, tape derived morse at exactly 20wpm.
Max.
KB3TZB
Joined Feb 9, 2018
10
Max.
What frequency does TASS broadcast on? I have an old Hallicrafters S20R that can probably pick it up. Thank you.
ak
I am testing the same circuit with a TIP31. With a tone tape input the resistance between the emitter and the collector at the TIP 31 is zero, but for some reason the sounder doesn't operate. Testing just the three volt sounder circuit, shorting out the collector-emitter leads works fine...Thank you for the advice.
MaxHeadRoom
Joined Jul 18, 2013
30,854
Whoa, we are talking 1957-8 training with The Royal Signals, We actually picked up the announcement of the Sputnik launch!.
I suspect they are still using the same freq., Interesting to know if they still do.
I ended up in Tripoli where we had a registered Amateur Radio station and we were kept up all night requesting QSL , particularly from the U.S. as there were only two Libya call signs at that time that we knew of.
Max.
KB3TZB
Joined Feb 9, 2018
10
Max.
Thank you Max...I was a sophomore in high school in 1957.
Status
