UPDATED
Hey Guys, I have a monitor that works and am trying to probe it out of standby.
So far through my research I can make it come out of standby for a moment, and then says no signal, and turns off.
I want to get it to stay on so I can screw around with it.
So I have the 6 standard connections setup on my breadboard, GND, R, G, B, VSYNC and HSYNC.
I have RGB connected to .6v, which should kick out an off white color if I understand. I can adjust my voltage to vary the color.
I have Hsync on a timer at around 60hz and vsync on that same timer.
Any ideas how I can use a voltage to generate a color?
