Mixing electrolytic capacitors
Gdrumm
Joined Aug 29, 2008
684
I have a roadside pickup eMachine that has 2 bulging caps, 6.3 volt, 1800 mfd.
I don't have the exact caps, but can I put two caps in series?
I have (2) 16 volt 1500 mfds, plus (1) 50 volt 330 mfd, plus (1) 35 volt 300 mfd.
So, a 1500 + a 330 = 1830 with higher than required, and non matching voltages.
And another set, of 1500 + a 300, with again slightly higher and non matching voltages.
Sounds logical to me, but I thought I had better run it by you guys.
Thanks,
Gary
Just found 10 pieces the right size, from China for $1.32, with free shipping.
I think I will wait a couple of weeks, and fix it right.
It's still an interesting quetion though.
Thanks
Lestraveled
Joined May 19, 2014
1,946
First, you would put them in parallel, not series.
Second, mixing caps in parallel is fine, just so long as the lowest voltage is higher than you need, (greater than 6.3 volts).
Gdrumm
Joined Aug 29, 2008
684
Good information, and thanks for the refresher on Series and Parallel.
I might go ahead and give it a shot, while I have two weeks to burn.
I appreciate the feedback.
As always,
Thanks,
Gary
takao21203
Joined Apr 28, 2012
3,702
in most cases, almost any similar part will do.
If it is a special low ESR capacitor, you need to know some circuits indeed are picky and wont work right if you use different caps. The circuit WOULD WORK, but the error detection shuts it off.
34,817
Oops. I didn't read the part "roadside pickup eMachine".
That is a different beast. The switch-mode supply on a computer mother board is a different story. They commonly have a number (6 or 7) such capacitors in parallel and require low ESR capacitors. Replacing through-hole capacitors on a multi-layer board is a pain and require the right tools and expertise and lots of patience. But it is doable. I have done a few myself.
Gdrumm
Joined Aug 29, 2008
684
Sorry,
It's a cheap computer made by eMachine that I found on the side of the road.
This one has Vista Home, with 2 gigs of ram, and an 80 GB hard drive.
The bad caps were on the mother board.
Gary
ian field
Joined Oct 27, 2012
6,536
Thanks,
Gary
Thanks
Those values sort of hint at ultra low ESR, the values are typical of what you're likely to find on a PC motherboard.
Scrounge some scrap MOBOs from a repair shop - you'll probably find 6.3V caps at least pretty close to the values you need.
Bad caps is a common failure on MOBOs - so you might have to weed through a few.
Gdrumm
Joined Aug 29, 2008
684
Update,
I scrounged, and found an old MB with the exact caps.
Now for the lesson of the day.
Don't drill the holes on the MB so the caps will go in easier............
I mean I measured the wire of the cap, and found it to be .034", so I got my pin vise, and a .035" drill, and drilled out the holes, thinking this would help me install the replacement caps easier..
I learned the hard way, that this action removed some of the metal to which the pin anchors to the board.
I like to never got the final pin soldered in.
Thanks for your expertise, again,
Gary
Update,
PC is up and running.
Thanks,
Gary
ian field
Joined Oct 27, 2012
6,536
Update,
Gary
PC MOBOs are usually multilayer. so some through hole vias connect to tracks buried inside the PCB layers.
If you run them through with a pin chuck and remove the via - you can isolate buried tracks that are next to impossible to patch with a repair wire.
Re-tin the salvaged capacitor leads and run the solder off the ends as you hold the capacitor up vertical, this should drip the blob off onto the tip of the iron, with an even layer of solder on the lead, you can see how straight it is.
Gdrumm
Joined Aug 29, 2008
684
Good tip.
Sounds similar to what I finally did.
With solder on the capacitor leads, I got them thru the holes, then added solder to them again.
While holding the iron on the leads, I pulled them back thru the holes slightly, then removed the iron.
I finally got enough of the lead to make a solid grab inside the hole.
I got lucky.
One of them took about 10 tries before it finally grabbed.
Thanks for the tip.
Gary
