Mixed circuit
WBahn
Joined Mar 31, 2012
33,240
You need to show your best attempt to work your homework as far as you can. We can then see what you are doing right and where you are getting stuck and help you gain the understanding you need to get past it and move forward.
WBahn
Joined Mar 31, 2012
33,240
It will help the grader (which is always a good thing) if you make it a bit clearer exactly what you are doing.
You seem to be finding the equivalent resistances of the upper resistors and then combining that with R5 based on the assumption that they are in parallel.
Redraw the circuit as it stands after you have combined the upper resistors and then ask yourself whether R5 really is in parallel with the upper equivalent.
JAMXX1019
Joined Oct 13, 2024
5
I don't know bro.
Do you know it
WBahn
Joined Mar 31, 2012
33,240
I don't know bro.
Do you know it
Yes, I know it. But I'm not the one that needs to recognize it on your next exam.
Draw the simplified circuit, after combining the upper resistors, as best you can and post the result. Either you do it right or you don't. If you do it right, then it is a matter of not recognizing what it is telling you. If you do it wrong, then it is a matter of not being able to redraw the circuit correctly. Two different problems with two different corrective actions. We are not mind readers, so we don't know which error you are making unless you show your work.
WBahn
Joined Mar 31, 2012
33,240
2.14A
I don't know , I prefer to think backward.
How are you getting 2.14 A?
Again, we are not mind readers. Unless you tell us how you got your answers, we can't help you figure out where you are going wrong.
So, again, what is the voltage across that wire?
If you are claiming that the current in that wire is 2.14 A, what are you doing to come up with that value? What is the resistance that you are using for the wire?
Show your actual calculations on how you got that result.
You need to become a lot more organized in your work and in your presentation of your work.
boostbuck
Joined Oct 5, 2017
1,064
Well, that doesn't seem to be working. Maybe you need to think differently.
Here's a question for you - if you connect a resistor of 5.6k (call it 'R5' for the sake of argument) in parallel with a piece of wire of resistance 0.0k, what is the total resistance?
35,199
You can state the question differently.
What is the voltage across a conductor of 0-ohms resistance?
Backyard
Joined Oct 15, 2024
16
Maybe try drawing arrows of all the current paths. Then calculate the resistance of each arrow or current path. Then add up all the current. Of you do this we can see how you are looking at the circuit and coming to your conclusion and maybe help you if you make errors
