MIW S-120-12 power supply repair
RodneyB
Joined Apr 28, 2012
698
I was given a MIW S-120-12 power supply.
When I connected it to the power on the 12 Volt out put side I only got 4 Volts. I tried to adjust the voltage with the voltage adjust but it made no difference.
I stripped the unit to see if I could see anything obvious and found nothing.
I re soldered all the components on the 12 Volt side in case of a Dry joint. When I tested again the voltage was 9 Volts. I tried the voltage adjust and again it made no difference.
I have searched using google un successfully for a circuit diagram.
I would really appreciate getting this to work .
RodneyB
Joined Apr 28, 2012
698
What is circuit controller (ic) of your power supply
For example most atxs' circuit controller is tl494
To be perfectly honest with you I have very little Knowledge with these power supplies. I was hoping to learn as I worked through fixing this. I will take some photos and send them
RodneyB
Joined Apr 28, 2012
698
Is the main chip a TL494, ideally take pictures of the pcb both sides.
Hi The main Chip is a KA7500
Now this is crazy but I dont know how to insert a picture . When I click on Image, I have to insert an Image URL and have no idea what to do from there
Dodgydave
Joined Jun 22, 2012
11,395
KA7500 is a TL494, to upload pictures click on "upload file"or "manage attachments"
then select the ".jpg " image
