Raymond Genovese
- Joined Mar 5, 2016
- 1,653
Yep. See Table 17 in the data sheet.It depends. You need to know the slgorithm used to generate it. There are several possibilities. If you can find the algorithm, you use the values that were read and re-calculate it. If the calculated number is the same as the transmitted number, life is good.
