Miniature garage door for doll house
Richieyoung85
Joined Sep 1, 2017
23
Im trying to figure out the simplest way to make an automatic garage door for my daughters doll house. Trying to basically model it after a normal one. Any advice?
Thanks.
MaxHeadRoom
Joined Jul 18, 2013
30,620
Are you thinking one piece door or sectional?
One cheap and possible way is a miniature geared DC motor with a small drum with a continuous cord arangement that winds up one cord as at releases/unwinds the cord on the other half of the drum.
Max.
Richieyoung85
Joined Sep 1, 2017
23
If i were to use a dc motor what type of switch would i use and how would i make it reverse? I would like there to be a switch to be able to open and close it. It would just be a small single panel door.
MaxHeadRoom
Joined Jul 18, 2013
30,620
Ah.. forgot that part, you need a couple of small Limits SW's or reed switch with button magnet.
You could put single miniature P.B. sw or simpler circuit would be two, up & dwn or small toggle.
Max.
philba
Joined Aug 17, 2017
959
I dunno, a hobby servo? They make some pretty small ones that might work for your scale. Wouldn't need limit switches. No feedback, though.
JohnInTX
Joined Jun 26, 2012
4,787
Take a look at the 'one piece pivot door' on page 11 of this Chamberlain opener manual. A single piece door with A frames on the back to pick up a single pivot point looks like a natural for a hobby servo.
Have fun!
Richieyoung85
Joined Sep 1, 2017
23
Here is one diagram, uses a small DPDT toggle switch, you can also get centre off if needed.
If you want auto reverse or single button operation as in a full size door, then it gets a little more involved.
Max.
Is the forward ls and reverse ls limit switches? Like would a micro switch with or without roller work?
MaxHeadRoom
Joined Jul 18, 2013
30,620
A micro type switch is what I had in mind.
If it hits the limit and keeps running it is usually because the diodes are backwards for the specific limit, in that case both are changed/reversed.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,620
Coincidentally a friend asked me to come up with something to simulate the control of a typical garage door with all the logic using 1 P.B. to control up/dwn/stop/fault (if both up/dn limits open) etc.
I am using a 8 pin Picmicro.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,620
You may want to look at a miniature motor with a high reduction gear box, this enables a smaller motor to be used and less demand on the battery.
Also helps in scaling the operation rate to a realistic level.
Max.
