I have a MKR1000 board mounted on top of the MKRMotorCarrier and connected to an IMU Shield that uses GND-3V-SDA-SCL pins, which leaves the MKR1000 available with RX, DAC0/A0, SCK, MOSI, GND, TX, MISO, and Digital Pins 7 and 0. I want to include a Mini USB Host Shield 2.0, but I've never used one before. What are the pins that the shield requires to connect to the board and what pin values (if any) would I have to change int the shield's library?
Thank you
Thank you
