is RY2 opening and closing? And just because you find zero ohms when it's closed doesn't mean it's conducting the full current needed for the MOT. If door sensors are faulty then you can set a time but when you hit start it won't start or count down. If everything in the system seems to be working correctly then either the relay can measure zero ohms but be bad - or you have a bad wire, plug or connector.
I'll go back to my suggestion of testing whether you have 110VAC on both terminals of the relay with a load attached. Like suggested, disconnect the MOT and rig up a test lamp. If the test lamp goes on and off with the timer control then you may have a bad wire from the relay to the MOT. I can't zero it in any closer than that. Unless your "Cooking Power Level" is set to zero (if possible) or 1. Meaning it will be on 10% of the time.
Stranger things have happened. I was given a TV because it was haunted. You could turn on then 15 minutes it shut itself off. When I got it I checked the sleep timer. It was set for 15 minutes. Check your power level setting.
