put a second microphone at 90-degrees to the first to capture environmental noise and use common mode (differential amplifier) to amplify only the directional noise from the primary microphone. It takes some time/effort to balance the two signals if you have reflections and not in an open space but, it can work. Essentially a noise-cancelling microphone.The problem is that due to the environment I am getting feedback at some mic locations.
It's not the high pitch oscillation but rather the low frequency oscillations. Like the one you get when you enclosed the the mic in your palm the oscillation slowly builds up to the point that amp cuts off. I can stop it by reducing gain but that reduces the volume too.
No matter where the speaker is it happens due to the objects with in the room which cannot be moved.
I am looking for a way to actively cancel out that feedback.
Interesting.The Behringer Shark is quite effective at eliminating feedback. However it does so by eliminating (filtering) the offending frequencies so a little of the sound quality can be lost.Not so important for the spoken word but not ideal for some musical instruments or singers.
