microcontroller with 80 io port
solehin robian
Joined Jan 27, 2014
10
hello there. i am doing an electronic abacus for my project. i use infra red sensor as the input. but i have problem on finding suitable micro controller that has high amount of i/o pin. where at least i need 80 digital i/o pin. can anybody suggest what is the best microcontroller should i use.
your answer will help me alot.please
35,171
You don't really need a microcontroller with 80 I/O pins. By using multiplexing techniques you can reduce it to 8 x 10 = 18 pins.
You can also use serial port expanders (shift registers) which would require only 3 or 4 pins interfaced to the MCU.
solehin robian
Joined Jan 27, 2014
10
i have consider about using multiplexer but there is also other problem where there is for 74ls series multiplexer, there is pin a,b and c to be as other signal to select the data from x0 to x7. i kind of confuse here at this a, b and c pins is. can you explain this. please i really need this information. thank you very much
35,171
You misunderstand the concept of multiplexing.
There is no need to use 7400 series multiplexer in order to multiplex I/O pins.
The concept of multiplexing in this context is referred to as "time division multiplexing".
shteii01
Joined Feb 19, 2010
4,644
one other question. is it possible to connect multiple i/o expander to a single mcu?
Yes. The question is: Do such extenders exist?
Basically my idea of multiple MCU feeding a main MCU is such extension scheme. The additional MCU are extending the number of I/O pins that the main MCU has. That is all they are doing.
However, there might be a simpler solution. I have been accused before of using MCU where something else can be used.
solehin robian
Joined Jan 27, 2014
10
thank you very much now i have much more understanding. i will give a try on this solution. your reply give me more knowledge about this world of mcu. thank you very much
solehin robian
Joined Jan 27, 2014
10
Before you go any further you should define what you are trying to accomplish.
actually i want to use 60 ir sensor to detect 60 beads on abacus and 4 push button for user to choose 1 of 4 operation that is addition, subtraction, multiplicatian and division. therefore i need around 70 i/o port including 16 lcd display as the output
atferrari
Joined Jan 6, 2004
5,029
Just in case, from the top of my head, from Microchip, 18F97 or very close to that. Once you find it, look for the package. It is not DIP for sure.
35,171
I can think of a number of ways to solve this problem.
The first solution is to use a number of 8-bit parallel-in serial-out shift registers. Eight such chips will allow you to detect 64 inputs.
If you are going to add extra chips in any case you may as well use microcontrollers (mcu).
You could use UART communications of mcu in a network where you connect all RXD together and all TXD connector. You use a communications protocol so that each mcu has a unigue address and is commanded to respond only when its address has been received.
Another solution is to use ISP interface. Each mcu has a separate Slave Select (SS) signal coming from the master mcu.
russian
Joined Sep 1, 2012
56
stm32f4 would be pretty close - like 50? 70? digital pins.
Then you can use i2C 8 bit port extenders - you can have up to 16 port extenders on the same two wires I2C bus. 8x16=128 I belive.
elec_mech
Joined Nov 12, 2008
1,500
Yes, you could use an I2C I/O expander such as the MCP23017 from Microchip. That one has 16 I/O's, so you'd need 4-5 depending on how many I/O's your microcontroller (uC) has. Only need 2 I/O pins from your uC to run multiple I/O expanders.
atferrari
Joined Jan 6, 2004
5,029
Right now, sitting on my bench there is a design where 8 bytes of data are serially shifted throug eight 74HC595. The micro in charge (18F4520) is clocked at 40 MHz what makes for a 10 MHz SPI's clock. It works.
