Microcontroller usage
Poul Meinhard Poulsen
Joined Oct 27, 2014
5
Hi
I'd like to make a small survey, about which microcontroller you use, and from which nation you are from.
this is suppose to be used in a project we're doing.
If you would like to specify why, you use these microcontrollers, then you are welcome to do that.
Or if you have a history of another microcontrollers that you've used, you would be welcome to share that too.
thank you in advance
Best Regards
Poul M. H. Poulsen
ISB123
Joined May 21, 2014
1,236
I use Atmel MCU's, most of them are ATtiny or Mega.
I use Atmel ones because I have Ardunio which can program AVR chips so I don't have to buy dedicated programmer.
Usage: CNC controllers,PC input devices and for some other "simpler" projects.
takao21203
Joined Apr 28, 2012
3,702
Thats funny, essentially the Arduino is a programmer. There are also USBASP programmers, some smaller Arduinos dont have USB.
30,806
In the past PDP11, Intel 8085.
Currently Microchip 18F series.
Small powerful instruction set.
Peripheral capabilities.
Availability.
Support.
Cost.
Centre of N.A. Canada.
35,145
I have used 1802, 6502, 6800, 6801, 6802, 6805 6809, 68000, 4004, 8008, 8085, 8088, 8086, Z80, MC146805, 186, 286, 386, 486, 8035, 8051, 68HC11, AVR, PIC, HC908, HCS08, TMS320, ADSP-21992, DSP56F807, MSP430, STM32F407.
Did I forget something?
33,155
Interesting homework problem.
I don't do a lot of microcontroller work (mostly ASIC design), but when I do I use the PICs because it is what I am familiar with and as long as they meet my needs I can't justify the overhead of switching. I primarily use them in test systems to test our ASIC designs.
jpanhalt
Joined Jan 18, 2008
11,087
Microchip PIC's, because when I started there were tons of tutorials for them, like Nigel's and Easy PIC'ns. I had an early Ti 99/4 (Ti Basic) and had used Microsoft basic (early PC) at work. Twenty years later, I was just too old and lazy to learn a new language. MPASM has done fine by me. I don't consider the cost of PIC programmers in the least bit significant. I started with PICStartPlus, which was great, then used PK3 for a short period (lousy power supply), now I use an ICD3. Basically, it works and does what I need. Why change?
John
