Microcontroller Based Signal Generator
chamara
Joined Oct 22, 2011
21
Requirements
>Resolution:Maximum 20mV
>Range:--2.5Vto +2.5(should be adjustable 2 buttons-up/down)
>Frequency Range:0 to 10 kHz (should be adjustable 2 buttons-up/down)
>Waveforms:square/sinusoidal/Traingular(should be selected using toggling 1 button)
>When the systen is powered on,the frequency,level and waveform shape used on the last use should be used as the default values
Can u tell me which PIC is good for make this Signal Generator?
lightingman
Joined Apr 19, 2007
374
You could use a PIC micro and an AD9833.
The required frequency, waveform and level can be sent to the AD9833 over the three wire interface. They are quite easy to use, but you really must read the date sheet very well.
Daniel.
atferrari
Joined Jan 6, 2004
5,031
Daniel.
He is trying to control output levels. How would you do that with the PIC and with the AD9833?
