Method to measure maximum energy stored in battery
Grim_hitsu
Joined Nov 10, 2016
5
Hi guys, I'm trying to measure the maximum energy stored in a battery but I'm not allowed to use any stopwatch or timer. Is there any other method to measure it?
AlbertHall
Joined Jun 4, 2014
12,663
Take a very well insulated (against heat loss I mean) container full of water and connect the battery to a resistor in the water. Then you measure the temperature of the water at the start and then watch the temperature rise. When it stops warming up, the difference in temperature and the specific heat of water will give you the total energy delivered to the water.
Dr.killjoy
Joined Apr 28, 2013
1,196
For me I could just guess and be pretty close as most battery are pretty close in value..
Or cheat and measure the battery and type ,then search google for similar battery..
Grim_hitsu
Joined Nov 10, 2016
5
Thank you so much for this brilliant idea, can I know what value of resistor would be suitable for this experiment?
#12
Joined Nov 30, 2010
18,224
Can we know the voltage and amps-hours alleged to be in the battery?
For that matter, you can calculate energy by knowing the voltage and amp-hours in the battery.
The question remaining is, do you want to do the math while allowing for the decrease of voltage during discharge? Do you want to estimate for a new battery you might buy? Do you want to measure the reality of one battery in whatever condition it is in today?
dannyf
Joined Sep 13, 2015
2,197
measure the current (+ voltage optionally) until the battery is fully charged. the area under the current vs. time plot is the capacity of the battery, in mah.
Grim_hitsu
Joined Nov 10, 2016
5
The battery i'm using is an AA battery with voltage of 2V and 2600mAh. I'm planning to measure the maximum energy for 2 different kind of batteries which one of them would be a fully charge rechargeable battery and a newly bought non-rechargeable battery. The condition on the day of experiment wouldn't matter
debe
Joined Sep 21, 2010
1,419
This is what I use for checking battery capacity, from Ebay for $6 free freight. You just set the voltage that you want the test to terminate. Then read off the Hhrs accumulated on the display. While its working it scrolls through current draw & Voltage & Ahr.VOLTS.2.JPG CURRENT.2.JPG Ahr.JPG
#12
Joined Nov 30, 2010
18,224
debe just showed you an excellent method. You can do pretty much the same thing by attaching a volt meter and watching the voltage until the battery is weak.
According to my old Radio Shack battery book:
An alkaline AA is rated as 1.5V and can power a 4 ohm load for 228 minutes as it fails to 0.8 volts.
A ni-cad AA is rated for 1.2V and has about 1/2 an amp-hour in it.
Some NiMH AA batteries are rated at 1.2V and contain 2.6 amp-hours.
So, it looks like about 4 ohms, 1 watt, and most of a day to test a couple of batteries.
