What is true RMS ?
Did the true RMS make difference for measurement with multi meter for frequency OR voltage OR amperage ?
"RMS" is an acronym for "root mean square". You can get an explanation here.Thanks JDT
I have some questions
What is the words meaning of TRUE RMS ?
What parameters the measures are incorrect in other words they don't have input of sin waves ?
What parameters the measures are correct in other words they have input of sin waves?
I used the multi meter to measure consumer that used 110 volt
Most meters measure the average value of an assumed sinusoidal wave. This equates to 1/∏∫Sinθ.dθ from 0 to ∏ which works out to be 2/∏ or 0.64 x the peak value. Since the RMS value is 0.707 x Vpk then the meter merely has some scaling circuitry which multiplies the average value by 0.707/0.64 = 1.11What is true RMS ?
If I don't have sinusoidal wave
Are existents consumers that I can't activate after that in my calculus I receive 110 volt RMS ?
Can you restate the question?Are existents consumers that I can't activate after that in my calculus I receive 110 volt RMS ?
