Metal detector circuit on Proteus, help.
Ali Awan
Joined Dec 2, 2023
1
Hey there I'm currently working on project named metal detector circuit on Proteus there is no waveform showing on Proteus even there is no mistake in circuit can anybody help me in this regard.IMG-20231130-WA0056.jpg
35,279
Congratulations on posting the longest thread title on record.
Now can we change it to something more succinct such as “Metal detector circuit in Proteus”?
Ian Rogers
Joined Dec 12, 2012
1,136
To use the scope you need to place the ground on the negative rail somewhere.
I almost never use a battery. When using Proteus, the best option is to make small circuits ( check it works ) then redraw with digital equivalents, other wise you will be simulating syrup.
I think most of the virtual instruments require a ground.
