It costs a bit less than an unknown product, and you do get to know all of the details before ordering.12 x 16 x 8 probally have to go to an electrical enclosure, Vevor have one at exactly those dimensions.
VEVOR Steel Electrical Box 16" x 12" x 8" Electrical Enclosure Box 304 Stainless Steel Electronic Equipment Enclosure Box IP65 Weatherproof Wall-Mounted Metal Electrical Enclosure with Mounting Plate
Is that inches? How about a 19" rack case?I looked at a-zon, didn't find much at all.
OA is something like 14L x 8W x 10H. Has to be all metal.
I need to mount the MOT, a hefty 200A rectifier that's on a large heatsink, two 63v 20,000mfd caps, and a 300A shunt inside. On the front panel will be two analog round gauges (0-10v and a 300A/75mv), a 1P6T rotary that provides x1-2-3-4-5-6 scale to the V meter, and two 35-50 DINSE ports. I am trying to build it completely passive, but I probably do need to add a cooling fan to the heatsink, this would also discharge the caps back down when not being used.
What If You Removed Every Electron From 1kg of Metal? (And Placed it on Earth) | General Science, Physics & Math | 13 | |
| T | does anyone know the state of copper metallurgy? | General Science, Physics & Math | 2 |
