The insulation test generates 500V - so make sure your DMM can handle that much!on a digital multimeter
Mine says 600 v ac/dc and china. Good enough ........The insulation test generates 500V - so make sure your DMM can handle that much!
I'm thinking of tacking it to my recent exercise timer - to give the trainer a job to do. Now I kow that 500v is more than 2v I may change tack. What to do with 500v that's friendly?You'd get more excitement charging up a 385V 560uF reservoir electrolytic - but you'd have to stand there winding the handle an awfull long time!
Simultaneous Disposable and Camera were not in our vocabulary at the time!Nowadays its easier to use the inverter from a disposable camera - smaller and more discrete.
But it is *nowadays*.Simultaneous Disposable and Camera were not in out vocabulary at the time!
Max.
NO! Really?But it is *nowadays*.
is post 22 enough or would you like larger Bill?A picture of the inside is worth a 1000 words.
Its a long shot - but what's the Ohms per volt of you'r DMM?Mine says 600 v ac/dc and china. Good enough ........
No only probe connections.Ours has a switch on the side marked "discharge" does yours have something similar to that? It would explain the low voltage...
Thread starter | Similar threads | Forum | Replies | Date |
Using megger with relay | General Electronics Chat | 5 | ||
mismeasurement multimeter MEGGER | Technical Repair | 9 | ||
M | Megger vs Hipot | General Electronics Chat | 12 | |
T | use of megger | General Electronics Chat | 2 | |
S | Megger operation | General Electronics Chat | 1 |
