Measuring Phase difference between two signals
uzumakiibram
Joined Dec 7, 2016
Hi, guys.
I need to measure the phase diference of two electrical signals A & B, with same frequancy - 40kHZ, signal A = 5.5 V - Urms, signal B = 8.7V - Urms. Can you give me the chematics to realise the masuring of the two phase diference in practice? Sorry for my broken english.
MaxHeadRoom
Joined Jul 18, 2013
30,813
We would use a double beam scope as in #3 to create a Lissajous figure in order to align the early quadrature (90°) measuring scales, they had incandescent lamps so when replacing a dud lamp the Lissajous figure was used to create the 90° 1:1 circle in the list shown.
Max.
MrAl
Joined Jun 17, 2014
13,796
Just wondering, are there any limitations on the amount of phase shift possible? For example, max 90 degrees, max 60 degrees, etc.
MrAl
Joined Jun 17, 2014
13,796
Depends on the ratio between the two as to how readable it becomes, the 1:1 shows 0-360 possible.
Max.
Hi there,
Sorry my 'bad', i meant that question to go to the OP in case their problems had limited phase angles in which case there may be other ways to measure the phase angle.
