Measuring Output Ripple Voltage Problem
Electronic_Maniac
Joined Oct 26, 2017
253
hi,
Please post the question and drawings on this Thread.
E
Boost IC = NCV3063
Vin = 8V
Vout = 23V
Iout(max) = 250mA - (Load is a constant current circuit which is enabled at 200Hz)
Schematic
Circuit Schematic
Mentioned the points where I have probed
Waveforms (Same waveform, only varying the timescale) :
Why is there a dip in output current and increase in output ripple voltage at the marked areas?
And which waveform describes the right Peak to Peak ripple voltage measurement?
This :
5
Or
6
Or
7
ericgibbs
Joined Jan 29, 2010
21,573
hi EM,
I always measure the ripple voltage at the output of power supply, when it is loaded with a fixed load that draws the maximum current specified for the PSU.
What is the duty cycle of this switched load.?
E
Electronic_Maniac
Joined Oct 26, 2017
253
hi EM,
E
I too measured the ripple voltage at the output of the power supply as I mentioned in the diagram. Please tell me which waveform is correct.
And the duty cycle is 90%
ericgibbs
Joined Jan 29, 2010
21,573
I have already answered your questions.?
Because your switched Load is creating the change in the circuit response waveforms
As per my post #6
But why should I not do like how I do? What's wrong with my own load at the board
If I have missed a point, please repost a particular question.
E
