Measuring charging current of the Capacitor
t.haliulin
Joined Nov 3, 2021
24
Hello All,
I am trying to get a circuitry that will measure charging current for the capacitor.
Given parameters are: Functional generator: 20Vpp with 1kHz frequency. Capacitor value is 1nF
I know that the current will be extremely low - 87uA RMS.
Is there any solutions how to measure it?
neonstrobe
Joined May 15, 2009
200
Put a resistor in series and measure the voltage across it.
e.g. 1k
You will need an a.c. millivoltmeter (or an amplifier with a known gain) to measure.
And check your maths on the expected current.
t.haliulin
Joined Nov 3, 2021
24
e.g. 1k
Thank you. If I am going to implement resistor do I need to place to two amplifiers on each end of the resistor and measure difference?
Expected current was achieved from the simulation in LTspice, it is wrong?
t.haliulin
Joined Nov 3, 2021
24
If one side if s at ground you need to measure onky one voltage. Otherwise a differential amp is used.
Bob
Thank you, resistor would be in series with the capacitor, therefore differential amp is considered using, but from the experience would it be sufficient to use resistor with diff amp to measure that low currents, as I have no experience for low current applications?
t.haliulin
Joined Nov 3, 2021
24
There are special current sense amplifiers.
Bob
I have used previously current sense amplifier for the motor control circuitry, but its resolution and other parameters not really suitable for me.
Are you aware of any AC current sense amplifiers for low current measurements? I was struggling to find any
Ian0
Joined Aug 7, 2020
13,207
An AC current sense amplifier doesn’t actually know the current that is being measured, all it knows is the voltage across the shunt resistor. It will work at any current value, with an appropriately chosen shunt value.
t.haliulin
Joined Nov 3, 2021
24
I know that it is measuring voltage difference, but with such a low current would it be able to actually see the voltage difference between across resistor?
ericgibbs
Joined Jan 29, 2010
21,517
hi t.h.
This is the most basic circuit of your project, so that we have a reference circuit to discuss.
Note: the Capacitor current.
E
BTW: Which type/construction is this 1nF...
Ian0
Joined Aug 7, 2020
13,207
Yes, if you use a larger value resistor!
The limiting factor is the offset voltage of the amplifier, which will be in its datasheet.
[edit] included TS’s question.
t.haliulin
Joined Nov 3, 2021
24
If I will use larger value resistor, then the voltage waveform across the capacitor will reduce its amplitude and will be shifted, probably that is fine, but ideally I want to keep certain amplitude of the voltage for a device
