Measure resistor with a Multimeter
kalemaxon89
Joined Oct 12, 2022
389
I have a 10k NTC at 25 C° and a 10k resistor in series, connected between the arduino's 5V and ground.
With the multimeter I would like to measure the 10k resistor (even though I know it is 10k) out of curiosity... but when I connect it to the circuit and connect the two probes of the multimeter to the resistor ends, the display shows "1." (i.e. out of scale).
This is impossible because I selected 20k in the multimeter .. so 10k should measure it.
Additionally, if I measure the same resistance disconnected from the circuit, the correct value of 10k is read from the multimeter.
What is happening?
EDIT: I've just tried to measure it again and now the display shows 14k .. how come?
BobTPH
Joined Jun 5, 2013
11,557
First of all, you should not expect correct readings of any component in circuit since there are other components involved.
But getting a higher reading in circuit for a resistor should not happen unless you are measuring with the circuit powered, which you should never do!
kalemaxon89
Joined Oct 12, 2022
389
Since this is my first time using the breadboard and making a circuit, I am measuring with the circuit powered. Thanks to you and @ericgibbs for the advice!
But I wonder, how can such a circuit (or whatever circuit it is) affect the resistance value ... shouldn't it remain constant at 10k ?
BobTPH
Joined Jun 5, 2013
11,557
The resistance remains the same, but when you put the multimeter probes across the resistor it cannot measure the resistance of that resistor only, it measures the resistance of the entire circuit between those two points.
Think of a very simple circuit. Put two 10K resistors in parallel. Now try to measure the resistance of one of the resistors while in that circuit. What do you think you will get, and why?
kalemaxon89
Joined Oct 12, 2022
389
hi,
The fixed 10k series will retain its value, the NTC resistance will reduce as the temperature increases.
E
But why if I try to measure the 10k resistance with the multimeter while the power is on ... I see a value quite different from 10k ohms?
sarahMCML
Joined May 11, 2019
699
What is happening?
Your multimeter works by passing a known, accurate current through the resistor being measured, in this case R1, and measuring the voltage across it. But in your circuit, when it's powered up, you also have current flowing through it from the power supply, so this confuses the multimeter, so it measures a different voltage. Hence the wrong readings!
Even un-powered you would have a current path around the circuit, through the PSU (unless disconnected) via the thermistor, which would also give an incorrect, lower, reading.
BobTPH
Joined Jun 5, 2013
11,557
Go back and read my post #7 and @sarahMCML’s post #9. If you don’t understand them, tell us what you are not getting.
34,884
Your resistance meter does not measure resistance. It measures current.
Think about that for a moment.
The meter applies a voltage and attempts to read back current.
If the circuit is still powered and the circuit voltage opposes the meter voltage, the measured current will be lower than expected. Hence the readout resistance will be higher than expected.
kalemaxon89
Joined Oct 12, 2022
389
Done.
When the circuit (powered with 5V from Arduino) is off of course the multimeter reads 10k .. when it's on, it reads "1" out of scale on the multimeter for both.
Indeed, when I touch with the terminals of the multimeter the ends of one of the 2 10k resistors ... the display of the multimentro goes out. When I disconnect the terminals (probes) it turns back on.
kalemaxon89
Joined Oct 12, 2022
389
Il multimetro funziona facendo passare una corrente nota e accurata attraverso il resistore da misurare, in questo caso R1, e misurando la tensione attraverso di esso. Ma nel tuo circuito, quando è acceso, hai anche corrente che scorre attraverso di esso dall'alimentatore, quindi questo confonde il multimetro, quindi misura una tensione diversa. Da qui le letture sbagliate!
Anche non alimentato si avrebbe un percorso di corrente attorno al circuito, attraverso l'alimentatore (a meno che non sia scollegato) tramite il termistore, che darebbe anche una lettura errata, inferiore.
Measure resistance in a built (like PCB) circuit is difficult because current choose the "way" with least resistance, in fact the measuring current doesn't flow only in the resistor.
kalemaxon89
Joined Oct 12, 2022
389
Are you saying you don’t think the current would split half and half between two equal resistors in parallel on a breadboard?
Sorry, I misspoke. Please forgive my english.
I just edited the previous answer because it seems just as you said ... that is, the current does not split into two branches.
Of course I know that this is not the case.
kalemaxon89
Joined Oct 12, 2022
389
I have put the two resistors in parallel and cannot display the resistance (of either one) on the multimeter. I would like to know physically (I haven't figured it out yet) why this happens
34,884
Resistors in parallel
Any number of resistors in parallel will give you a single effective resistance between points A and B.
You cannot determine the value of each individual resistor by measurement with any type of meter.
If you know the values of all but one resistor, you can calculate the unknown value using the parallel resistor equation.
