MCP9700 sensor problem
ilginsarican
Joined Jul 13, 2017
147
I am working on the vehicle air conditioning system.
There are 3 blower fans(24Vdc) and 4 temperature sensors(MCP9700) in my system.
The blower fans have 3 speed stages.
When the speed increases ,the sensor output voltage increases too.(Temperature is constant)
They have common ground(Vehicle body).
İs there anybody who knows that why sensor output voltage increases?
Dodgydave
Joined Jun 22, 2012
11,395
The Mcp9700 gives out 10mV per deg C,and has an offset of 500mV @zeroC, on a 5v supply, if your output is changing without temperature there must be a supply problem or the sensor is faulty.
Reloadron
Joined Jan 15, 2015
7,889
That's it. If the sensor VDD remains a constant less a temperature change the sensor output should remain constant. I would monitor VDD and see what it does with changes in blower speed. You may also want to look at VDD with a scope for any noise changes with blower speed change. Beyond that there really isn't much to look at.
Ron
dendad
Joined Feb 20, 2016
4,637
How is it all wired?
The sensors would be best to not share any wiring with the fans, but connect via dedicated wires back to the controller. Then and fan motor current induced voltage drops will not impact on the sensor reading. Like #12 says, suspect ground connections can cause problems. Some times really odd ones.
ilginsarican
Joined Jul 13, 2017
147
MCP9700 is on a pcb it takes 24Vdc voltage from main board via a cable.Main board controls blower fans.
and the sensor pcb ground connected to main board ground via a cable too.
I measured ground by an oscilloscope.I observed that when the fans start to work ,ground signal rises 930mV.
ilginsarican
Joined Jul 13, 2017
147
Ron
I measured VDD,VSS and sensor output.
VDD remains constant, VSS(ground) rises 930mV and then remains constant 930mV and the sensor output rises by blower fans stage.
And sensor works well another system.
bertus
Joined Apr 5, 2008
22,923
Can you post a schematic?
What is the supply voltage of the sensor itself?
The datasheet states it must be between 2.3 and 5.5 Volts.
Dodgydave
Joined Jun 22, 2012
11,395
@930mV the sensor is sensing 43C, if it's not at that temperature you must have a bad supply, probably the ground.
bertus
Joined Apr 5, 2008
22,923
You CAN post schematics using the "Upload a File" button, below the reply window.
The pop-up will show you wich extentions for the file are allowed.
ilginsarican
Joined Jul 13, 2017
147
Yes you are right ,I figured out that the problem was ground conne
I mean the company I work for prohibits to share schematics.
Thanks anyway
