MC5100 Treadmill Control Board
vikinginging
Joined Sep 3, 2021
Hi, new to the form here.
Is anyone familiar with the MC5100 control board? Hoping to use with a PWM generator to control a motor for a lathe. Would it have the same PWM frequency as the MC2100 board (50ms/20hz)?
MaxHeadRoom
Joined Jul 18, 2013
30,808
Appears to be a updated version of the other MC2100 versions, there are a few.
It has the same HD2 socket but 12pin instead of 8., so I am thinking the PWM signal might be the same.
vikinginging
Joined Sep 3, 2021
Screen grabbed this from a youtube video of the same board being replaced. Only the first 8 pins of the socket are used, and have the same colors (which i know could mean nothing) as the MC2100 diagram indicates. Going to order the parts for a PWM generator and will report back.
vikinginging
Joined Sep 3, 2021
Ok, I can confirm for anyone else that comes across the mc5100 board the pin outs are similar to the mc2100
Pin 1: ground
Pin 2: 12v dc
Pin 4: PWM
Pin 8: ground
I have it running with a cheap xy-kpwm from Amazon, and a 50w50ohm breaking resistor. I'm using the same 20hz PWM frequency which seams ok.
Hi Max and Viking - long shot here but I have a Freemotion treadmill with a ghost of a motor control board and cannot get it running with a PWM. Icon MC5150HCL, can't find anything on the web but a single picture. Seeing as Viking has a MC5100 I thought it might be close. This input socket has 8 pins but only 7 wires, pin 1&2 (BLK&RED) being the only two that match the MC2100 pinout. Have tried every combo of PMW output connections and at a variety of frequencies and duty cycles.
My wife would like this very expensive and heavy anchor working again. Maybe its worth parting out.
Any thoughts? Maybe the resistor Viking mentions - how is that wired? Thank You!
nervitesi
Joined Jun 14, 2024
Pin 1: ground
Pin 2: 12v dc
Pin 4: PWM
Pin 8: ground
Hi, I have an MC5100 board but I can't get it to start with a PWM generator. Can you help me, maybe with a diagram of how to connect the resistor? Thanks in advance.
MaxHeadRoom
Joined Jul 18, 2013
30,808
First you have to measure the existing resistor that goes between Pin 4 of HD2 and the input of the 4pin octo-coupler.
Then dependent on your peak PWM voltage the combination of one required in series and the one on board should restrict the current to a maximum of 50ma.
Aim for ~30ma.
DazeCars
Joined May 22, 2026
Aim for ~30ma.
Where was the breaking resistor connected?
