MC2100WAM pinouts
animal12
Joined Feb 20, 2018
48
The new one I ordered yesterday was $ 12.60 , the one I broke yesterday was $13.90 2 years ago . go figure .
thanks
animal
animal12
Joined Feb 20, 2018
48
SO question , is that just hot glue they dab in each corner where the board hits the heat-sync ? I want to remove the board from the heat-sync & look at the bottom of the tall cap to the left of the D4 & D6 diodes which feels a tad loose to me . Just want to make sure that I'll be able to put it back together the correct way .
thanks
animal
animal12
Joined Feb 20, 2018
48
Ok , so I removed the board from the heat-sync to check the solder connections in the tall cap & everything looks good . There no signs of over heating anywhere . Is there something I should check out or replace while I have the board out of the
heat-sync ?
thanks
animal12
MaxHeadRoom
Joined Jul 18, 2013
30,813
So do you have the external transformer hooked up? If so trace the AC output to the two large diodes to GND,
It is a very simple circuit.
You should have the DC on the large electrolytic cap.
animal12
Joined Feb 20, 2018
48
Yea external xfmr is hooked up & supplying voltage like mentioned above . I'll give that a look see tomorrow .
thanks
animal
animal12
Joined Feb 20, 2018
48
That seems to be the issue . Like mentioned above with the AC xfmr installed & putting out the 20VAC there is no DC voltage on HD2 . That is what the problem is with the board . No DC voltage at HD2 , but there is AC voltage going into the board from the xfmr. So It is being stopped somewhere between the 20 VAC in pins & HD2 .
thanks
animal
MaxHeadRoom
Joined Jul 18, 2013
30,813
The circuit, IIRC, could not be simpler !
AC to a couple of rectifiers and a large cap, you should be able to trace the printed circuit quite easily.
The one I encountered had a fuse blown, .Is F1 OK?
animal12
Joined Feb 20, 2018
48
Spent some time the MC2100 today . I have 16 VDC coming out of D4 & D6 , the 2 large diodes which are right next to the tall cap in the lower left in pic 1 in post one . Still no voltage or pulses on the corresponding pins on HD2 & the fuse is still good . I have no clue what to try next .
thanks
animal
MaxHeadRoom
Joined Jul 18, 2013
30,813
Do you have any voltage on the HD2 pins? 1 & 6 are the common and pin 2 is the DC+.
From the rectifiers to the HD2 is just short traces?
animal12
Joined Feb 20, 2018
48
Nothing on HD2 Pins , no voltage , no pulses if I run a magnet on the reed switch . nothing . I believe it's 1 & 8 are common .
thanks
animal
